Do you think having too many studs?
Bullit01
Bonfield
Hey guys I was just wondering, I have a 01 srx and cant get the sled to rev with stock settings on top end. I've cleaned power valves and adjusted, checked carbs check suspension everything is to spec and clutches are all stock and tryed going 60,70,80 and 90 degree twist cannot make it rev on top end, it revs 8500 on the bottom end but then goes to 8100 on top. Know I was just wondering if the 192 studs would not let the sled rev on top end because of the weight? If anyone have any suggestions please let me know.
No 192 studs will not in anyway overpower the 145 horse on the srx. You either have something going on in your clutching, powervalves, or carbs.
Like holic said studs should not be hurting that monster at all,your back
shifting, try a search on srx clutching,there's a ol time favorite we run
with that sled,should help,make sure clutches are clean nothing wore out
belt(8DN OEM) is good.
get her dialed in and hold on!!!
