My Viper Mtn does'nt run well in snow as I said before in thread...
Now I'm in to check the clutch. When I drove over a lake "pedal to the metal", dry snow on top with pretty much water on the ice it revs 9000, speed 115 km/h (70 mi/h. Have made a mark on primary clutch and the belt is over 20 mm from outer edge with max throttle. Think the backshift is good.
So, a friend said that I should put a spring with same pressure in start (3900rpm) but softer in the end so the belt climbs up on primary and then it will rev less. Spring in primary is green-white or silver-green and secondary is green(not 100% sure but almost).
Is this standard and what spring should I go to in primary?
Belt is rather good 34mm wide and 1 mm over secondary.
