Viper problem
YamahaXtreme
Massachusetts
Website
www.freewebs.com
Alright guys, Im back with another guestion. I just got a new top end for my sled (middle cylinder only) She was riding great for the first 30 miles then I started to get a bog when letting off the trottle. Right around 4000 RPMS it would set in and I would beable to rev the sled back up till it went down to around 2400 RPMS. It makes the exact same noice as if the TORS were enabled. I've also gotten a few back fires not sure if this is a timing issue or what? Any help is much appreciated!
Concept Carbon said:
how old is your gas posible water or ice, and your positive it isnt TORS.
When was the last ime you cleaned your carbs
Brand new gas, dont think its water or ice feels. I honestly I dont have a clue. If it was the tors what could be causing this?
sounds like either the tors on the carb rack is faulty or the onet hats built into the throttle housing, try and loop the carb wires(the harness from sled)see if that cures it. If it does recheck the throttle cable, it may just be too tight and need some slack set in it.
If this doesnt help look up at the throttle lever and see if that one is working, you pinch the lever pivot and push on the lever to acivate the tors up there.
