Leak down test ?
If your talking for the cyl's i use a 100psi, it should hold at least 90psi no more then 10% leakage is what ya want..
I want to check for leakage thru the crankcase halves, the crank seals also, the base gaskets. 10% leakage per minute ? Thanks !
How do you go about doing a leak down test?
I want to learn how to do a leak down test on my sleds. Is there a write up on the site that I haven't seen? Could someone list some steps to do one?
Thanks,
Bruce
Thanks,
Bruce
Have you tryed a search on this,i thought me and othere's have posted
before on it..
Here is a LINK on the fundamentals and how to perfrom a leakdown test. It is for 4 cycle engine but the principle is the same. For anyone contemplating on buying a leakdown gauge tester, go with the two gauge unit instead of the single.
Right,,you couldn't do the test properly with out a duel gauge
set up
