ximportman
just got done rebuilding the sled, 00srx700, and took it for a ride and it is having a few problems, took it out to the feild ro ride, and it seems like the middle cylinder isnt getting any gas, and on the spark plug is a weird color, normally the middle of the plug is white, well its like a reddish orange color, like its sparking without fuel, could my middle carb have shit in thejets clogging the carb so im not getting any fuel, i tested the plug and it is def gettin spark.
viperino
if its not getting gas to the one cylinder, probably a carb issue.....clean them up and make sure the jets arent clogged
taylzee
It could be as simple as a fuel line not being hooked up. Check for spark, compression etc. And get into the carbs to checked for plugged circuits/vent lines.
ximportman
well found out what the problem was, the carb was clogged and caused the center piston to burn up again, so im down 1 sled again, but it will be fixed over summer and what not.
Sorry to here that.What a bummer.You must always make sure you clean them carbs out good and put in clean gas.Run a little Sea Foam in your tank to,helps to keep things running better.I would be really pissed if I was you about now.
