viper prblem
extreman1
just changed jetting went to 165 mains. idles fine as soon as i hit the throttle it acts pig rich just bogs, fouled plugs. its a viper with bender pipes.
ran fine with same jetting before. could this be the tors acting up or a electrical problem. did have issue with the tors switch on the idle adjustment screw. thought i had that fixed? seemed to be at 1/2 throttle to full throttle when it acts wierd. or could it be a power valve problem??? been through the carbs and there fine.
