Heat Exchanger help
yamaracer18
marcy, ny
well my fornt heat exchanger is shot put a few studs threw it track loosened up on me! How do i replace it and how easy is it to replace does anyone have instructions or somethin i can use. also where is the best place to get a new one. This is for a 2002 viper
If you can get to it with the track off, it can be welded. If you can get to it with the track off, you will have to get it out to weld it. It can be changed, but everything has to come out. The motor, steering, track, and suspension.
