I Was Wondering What If Would Take To Put A Viper Or Srx Big Bore With Tripple Pipes Into My Moutain Max Chassis? Is There Any Body Or Bulkhead Mods That Need To Be Done Or Will It Just Bolt In. Any Info Would Help Thanks Joby1
juniormax
front engine mounts are different if you have or know of a aluminum welder it can be done my boss has a 981 union bay srx motor in mm chassis
There have been a few posts on here over the last few years on the subject. If I remember correctly it is easiest to use a srx front cast piece with srx plastic. Check with betheviper, I think he was one who did put a srx motor in a sx chassis (same as mm).
