jclee71
Why does my sled (98 srx 600) take 5-7 pulls to start when I shut down and restart while riding, if it sits for a short time, like having lunch or something, then fires right up on 1 pull, thought someone mentioned on here this may be a sign of stator or something starting to go bad. Thanks for any info.
My sx did that exact thing. The stator was on its way out. After awile it took new plugs to get it going.Now with a new stator it starts on the first pull
viperino
this is common for the yammies.....both my sleds do the exact same thing....you need to hold the throttle when warm and they fire right up.....not sure why but this is normal on any 2stroke yamaha i've ever seen.
pipdviper
viperino said:this is common for the yammies.....both my sleds do the exact same thing....you need to hold the throttle when warm and they fire right up.....not sure why but this is normal on any 2stroke yamaha i've ever seen.
I agree. Mine does the same thing. I just open the throttle slightly off closed and it starts on 1 every time.
RIVERRUNNER
My srx 600 does the samething give it a little throttle and see what happens.....should start first pull...if that doesn't work then test your stator via the spec in the manual....pretty simple all you need is to ohm it....RR
stein700sx said:My sx did that exact thing. The stator was on its way out. After awile it took new plugs to get it going.Now with a new stator it starts on the first pull
x2. my SXr would get hard to start when warm.....then eventually, at the most inconvenient times possible, wouldn't start at all. that is how my last 2 stators have gone out.
horkn
Old rotary valved Doos acted this way as well. Esp the ones with no choke, only the primer. Talk about a PITA.
horkn said:Old rotary valved Doos acted this way as well. Esp the ones with no choke, only the primer. Talk about a PITA.
My old MXZ 670 did just that.
Sometimes I had to hold the throttle wide open and pull it over to get it to fire.My SXR and Viper need a touch of throttle to start when warm too. I wish my wife could start the sled on her own, but she isn't strong enough to pull it over with one hand and hold the throttle at the same time. I guess it's time to get her on a four stroke with electric start.
turbor
anybody has the specs to check the stator on a 98 srx? i have one here that kept fouling plugs, could not figure what was the problem, now on the last test run we did, it died and theres no more fire, we tought the previous owner had changed the stator, (we bought it witht the fouling problem, previous owner said he changed alot of parts could not find problem) i called him and he now said he did not change it, im sure my problem is there, jsut want to test it before i buy another one.
hey turbo if you start your own thread in the SRX forum someone will help ya out...
turbor
oops sorry, on another note all the srx's i've been around also like the throttle a little bit open when you start them and theyre hot.
Yamaha snowmobile stator repair in one day, someone gave the tip on this site, very cool. I have 2 friends this year that had to replace them. Place was on EBAY under item:
300198168115
RM STATOR
3033 ch. Audet
Ayer's Cliff Québec Canada
J0B 1C0
1-877-838-1399 or 819-838-1395
Fax: 819-838-1353
seany@rmstator.com
RMSTATOR INC Internet store is always open 24/24 7 days a week, all web orders will be shipped immediately.
300198168115
RM STATOR
3033 ch. Audet
J0B 1C0
Fax: 819-838-1353
seany@rmstator.com
