95 v-max 600 le problems
sledfreak89
michigan
Ive got a 1995 V-max 600 le. Totally stock. 3000 miles. After got it rebuilt 200 miles ago, it never ran right. It has a mid range bog. Idles fine, top speed is fine. I was told to check the OHM's reading.. Does anyone know what that should be? thanks.
-sledfreak89
Couple of ?'s Why was it rebuilt? Meltdown,etc? Did it have the "bog" before the rebuild? Were the carbs gone through at the time of rebuild? How do the plugs look? When the "bog" is there flip the choke on a little bit, it should either get better or worse. How are the clutching components? The more info provided the better. If the engine was rebuilt because of a meltdown I wouldn't run it in that condition or you may be doing it again.
