anyone with 38mm carbs on SXR or SRX
BADSXR
holly, mi
I was wondering if anyones running 38mm carbs on there machines with a piped or a big bore kit. I'm wondering your thoughts and kinda where you are at the the set-up of the carbs.
I used to run them. They work. I ran them on a ported 700 and a 780 in my SRX. If you go with 38's, get a set from a '98-03 Mach Z. The spacing is the same. You can even get away with the factory intake boots, but it's a tight fit.
