well at 6700mi im gonna put in a new set of plugs the br9ev s tip slighty burned away so i will change them out
So soon????
Dave M
Better check with dealer....they may warranty them..
xt700
- Jan 27, 2006
you may want to look into a set of rings with them plugs!
Pat
Pat
comp tested it 125, 125, 123 . the eng was treated with microlon years ago
what is microlon ?http://www.microlon.com/ i had to reclutch after useing it as my revs whent to 9000
horkn
those are good compression #'s. Esp for nearly 7000 miles
Compression tells little about the true health of a smoker,any wore out motor can build comp fast but can it hold it??(blow by) a true test for rings is a leak down test with no more then 10% leakage @ TDC ..horkn said:those are good compression #'s. Esp for nearly 7000 miles
just did a leak test 3 at 10%
I checked out the Microlon web site and looked at their products and would like to know which one you used.It should be straight forward here but did you get the small engine formula for 100-200 hp and dump it into the oil injection tank?
Huh??
All three cyl's had 10% leakage???? at what PSI???s fortuna said:just did a leak test 3 at 10%
i used there cl100 its was the better one . i used ther stuff many years ago . the the eng was tore down . the pist felt like they had a glass like coating on them. it seems there main cust base is areo .
