RIVERRUNNER
Ok guys I have been out testing some clutching stuff and I have a question for ya.......I have a been playing with different weights to see what the difference is.....But I am wondering about my helix....I have a bender 51/45 on my sled right now and my clutches are running out of hole 8300 to 8600 on top....I have stock weights loaded...I am wondering if I could get a little more out of my sled with maybe a 53/43........am I going to notice a difference in a couple of degrees? I should get a quicker upshift and a better clamp on my secondary with this change??? It also should backshift better correct? I don't see why this wouldn't be better....what do you think? I want what everybody wants, aggressive in the trails, but runs on the lake
New belt
clutches are cool to the touch
dishwashered clutches
8df-10 loaded
green white green primary
stock rollers
51/45 bender helix
green secondary 60 wrap
Thanks guys
New belt
8df-10 loaded
stock rollers
51/45 bender helix
Thanks guys
The bender helix shifts a lot more aggressive then a lot of the other makes.
try this on the 600 srx
8bu-00
stock primary spring
inner empty
2.4 rivet in tip
45/39 helix
silver secondary at 60 wrap.
8bu-00
inner empty
2.4 rivet in tip
45/39 helix
RIVERRUNNER
Thanks turk that will be the next set I try!!!
I've got that set up in my 600. It works pretty well. I don't see the greatest top speed numbers with it though, but that might be due to my big butt, lower gearing, and the 144x2" track its spinning.
I'm going to a 780 so once that switch is complete I could sell you my 600 clutching if you want to wait on it.
RIVERRUNNER
yeah let me know I am interested!!!! When are you going to change?
If all goes according to plan I'll be doing the switch over next week. I'll let you know when I pull the clutching out and if your still interested we can work out a deal.
