My light is flashing 4 times. Chart says its the TPS. Any clues of how to tackle this problem. It only does this at wot.
horkn
x2ryder said:You can buy the bit to loosen the screws at the hardware store. I bought mine at Menards. I have also seen them at Auto zone.
It should be a safety torx if it is like all the other japanese toys I have seen with TPS on them.
On some rec vehicles, the slot is not milled out, but can be. Then the tps can be adjusted for your satisfaction. If you like to tinker, you can can alter power delivery to suit you. Some here may say not to touch it, but it can be beneficial if you do it right.
fwiw, I have not touched the TPS on my XC, but I have on several bikes, and on my mustangs.
horkn
Sanka said:My light is flashing 4 times. Chart says its the TPS. Any clues of how to tackle this problem. It only does this at wot.
Yours is probably out of adjustment. Daman posted on the first page of this thread exactly how to do it. If it is out of spec, it needs to be replaced.
You will need a multimeter, a safety tox bit, and a bit of patience to do either.
