Vector88
hey guys
im gonna haul my motor out to fix a cracked off bolt in the case for the motor mount! i dont have a clue on how to bleed the oil pump! can anyone tell me how to do it step by step? i want to make sure i know how to do it before i decide to take the motor out!
It's not really to hard..
there's a bleed screw down by the pump bettwen 1,2 carbs,crack that
open and oil should flow out.
also you'll want to crack the line going to the fuel pump from the oil pump
run it till air is out then put it back on the fuel pump.
but before you do all this have some pre-mix(50:1) in the tank,so wile priming you'll be safe,then once that pre mix is run out your system will be all bled and reddy to go...
Just make sure you take note where all these lines go,so when re asembling
you wont have any problems..good luck!!!!!
This was a good post, I will be doing this next week when I put the Viper motor back in.
Take note then.Colorado Viper said:This was a good post, I will be doing this next week when I put the Viper motor back in.
03viperguy
informative, good to know
