I have a 97 vmax xtc 600 and the fuel guage does not work at all. How should I analyze the problem and what should I be looking for?
Thanks!
Thanks!
polaris500
I had the same problem when i bout my vmax. All though mine wasnt hooked up.
Check to see if the wire coming from the sending unit is hooked up.
The sending unit will be to the right of the fill cap under the plastic that covers the fuel tank.
If its all hooked up then check the float rod
If thats good
Then ya might have a bad sending unit.
If thats good
