clutch help?? Turk, Mrviper and others
Concept Carbon
Ottawa, ON.
here is my set up
srx piped viper with stock viper gearing. 250lbs rider
HC's with red spring
5.3 heel
4.3 tip
3.3 center
48/36 dalton with green spring at 50deg
sled engages at 4200 about and jumps right to 8700rpm and climbs quickly to 9000rpm.
temp was 32 degf or 0deg C
sled has never felt so alive I had the dreamo up to 187km or 117mph on a rail bed and still felt like it had more but ran out of room.
so I can only imagine how it will pull if i get rid of my over rev.
So what do you guys recomed should i add a gram washer to the tip or shoudl i take out the middle whieght and add 7gram to the tip.
or what about a grey spring.
anything helps thanks Jay
That is a very low helix for a piped viper. Add 1 washer inner & 2 to the tip.I would use a steeper helix.
also starting to wonder if my power is at a higher rpm from the modifications to the pipes, sence if never seen those numbers before, running 8dn-20s with 51/43 reving at 8500 and 8600 on top and would have trouble breaking 175km
just ried 6 gram tip 4.3 center and 5.3heel seems to almost be perfect goes to 8500 and climbs just over 8600 hard to judge though i was on a lake with about 6inches of fluffy snow so had to make a trail first
after a bunch mor etesting sled revs at 8700 and climbs to about 8900 then drops down to 8400-8500 and climbs seems to drop down at about 110mph and then climbs to to 117mph on speedo but temp light keeps on comming on so cant so wha tshe tops out at.
should I through a grey heel clicker spring in or add more wheight. or bring rap down to 50deg
