FirstGenCTD
I want to lower the track on my 86 phazer by maybe an inch or inch and a half, and was wondering if there is a place I can buy some new brackets or do I have to fab up my own? Any of you guys that made your own, do you have pictures? Also, when swaping the brackets, I just drill out all the rivets and re-rivet back together?
thanks,
matt
thanks,
matt
FirstGenCTD
nobody??
BigMan76
Check with CB PErformance for drop brackets; they are a site sponsor.
i need more cowbell!!hilarious
I'm going to make my own, Ive got some 1/8 " aluminum sheets that I'm going to use. I plan on sort of copying the stock ones just more drop. So two pieces, one straight riveted to the inside of the tunnel and another L shaped so it can rivet to the running board. Rivet 'em together and drill a hole. I've heard you should to drop the fronts at least 1/2 the distance of the backs so I'll probably go 3" in the back 1.5" in the front. WPS (western power sports) makes them too, but after the dealer marks em up you're lookin at 100 bucks. I'll try to post some pics.
Yep...I put on two sets from CB performance...they work great and easy to put on.
..SNAKEBIT..
REV you looking to do another Yammy?
early this month out in the Snowies I rode my Viper 1 day, 07 800 Summit 2 days, and 08 Nytro 1 day
