What is the trick to removing the water pump seal located under the water pump. It moves small amount, do I just pull harder. Have a new one in my gasket set. It is time to build a Viper motor tonight.
basicaly you just have to pry it out,assuming you mean the mechanical seal?mine just got completly destroyed when i did it.
Getting tools out as I write this your response is great, will get it off and put the new one on. Thanks.
