yamahauler4
Sled wouldn't run, did some major backfiring... pulled the exhaust/box/carb off to check, all was clean. Went through carb anyway. Now she seems to run well, but I can't get the bowl to stop leaking!! That little rubber seal... does it come out of the carb body? Replaceable? Twice had to re-remove... still drippin'. Ideas? Thanks!
ps - any online manuals for these sleds/carbs?
that should be a mikuni butterfly carb. that gasket should be availible in the carb rebuild kit.
yamahauler4
It is a Mikuni. Tried to lift it out a little, but didn't want to destroy it until I knew I could get a replacement. Thought if I got it out and just re-seated it, that may work. Didn't leak until I touched it.
