RIVERRUNNER
I have been riding with a big upper gap and I have read all of bethevipers posts...and I have the downloaded video.....LOL for all you guys out there that have transferrods and a stock srx noaction. Where should I adjust my transfer rods to acheive the 50/50 gap, that I am looking for? I also would like to make it so when I get into 2ft mogals it will not bottom every time. Once, every other is ok...LOL I am lighter then most at 165 with gear. I have been riding with the shocks a little softer then stock and the fra in the middle. But when I get on it I only have about 1 to 2mm of gap on the bottom with my transfer rods in the middle my top gap is like 10mm or so and my straps all the way out. Is this better then having the shocks at middle and the fra at soft? I was looking at it this way, with the fra in the middle and the shocks soft I will soak up the small bumps and when I get to the big ones it will not bottom as bad. Is this wrong? I know that I need an M-10 but I like the idea of getting the most out of the srx and calling it good
Any help would be great!!!
