ximportman
i need to know how to and what tp adjust the oilpump cable at
thanks
May as well do it right and do all your adjustments..
Do these checks in this order;
1st- set idle to 16- 1,7000 rpm's(@ operating temp)
2nd- set throttle end play to 2mm(adjustment for that is down at the carb rack)
3rd- set oil pump cable free play here and here to 21(richer)to 23(leaner)mm
then set choke anytime to 1.5mm
