ximportman
hey guys does anybody have a link for the online manuel for a 99sx-vmax 700?
i need to know how to and what tp adjust the oilpump cable at
thanks
thanks
srxeater
i believe its 23mm+or-1 correct me if im wrong here guys
^^Yep your right....srxeater said:i believe its 23mm+or-1 correct me if im wrong here guys
ximportman you may as well do it right wile your at it and do all
your cables.
Do these checks in this order;
1st- set idle to 16- 1,7000 rpm's(@ operating temp)
2nd- set throttle end play to 2mm(adjustment for that is down at the carb rack)
3rd- set oil pump cable free play here and here to 22(richer)to 24(leaner)mm
then set choke anytime to 1.5mm
email me and I can send the sx venture manual to you. bkrpaul@aol.com
