srx2die4
- Oct 17, 2005
whats needed to setup 8" riser
After riding this weekend with stock bars on my 99 srx, I have decided that a riser and loop is a must! What all is needed to set up an 8" riser from stock? Any good links on where to buy? Thanks
juniormax
your gonna need some good cables I have a 2 inch pivot riser a 6 inch powermadd riser and 05 apex bars on my 98 srx and I had to get motion pro throttle and oil cables and a new steel braided brake cable I got lucky and didnt have to make any of my wires longer but some ppl do
I'm running a 6" riser plus the pivot adaptor on my stock bars. Had to use a longer brake, throttle, and oil. I threw my parking brake away so I don't know if that one will work or not. I had to extend one wire. Everything else was fine.
bolin22
http://www.gravityworxracing.com/ExtendedThrottleCables.html
the guy said it is possible to run up to 10" rise higher than stock with these cables...they look real sweet too.
Dave M
WOW...he sure is proud of his cables......
