ReaperSRX
How does the gap effect the PV clearance? Example, does having 2mm of gap pull the valve tighter in or does 3mm? Just need to know because i didn't have any 2.5mm allen wrenches and used 3mm but just not sure if that make the PV tighter and could pull through....James
2mm would pull them open more then 3mm.
ReaperSRX
Thanks! That's what i figured, just wanted to be sure. I would rather be a little off rather than too tight and cause a pull through.......James
edunn69 is right...
spec is 2.0 to 3.5mm but 2.5 is the norm,,you'll be fine..
pvggreenville
How do you adjust the valve cable with out actually knowing whether or not the valve is also moving?
It just won't....if your using the 2.5 A/Wpvggreenville said:How do you adjust the valve cable with out actually knowing whether or not the valve is also moving?
