I have a 1999 srx 700, After two hours of riding with brand new plugs it starts to run terrible, I think it maybe the stator, because it takes more power to run older plugs than newer plugs,now my sled also has been polished and ported and has a thicker base gasket to shim up the cylinders. so i have tried rejeting, gone to the original gasket and have ran hotter spark plugs, but nothing seems to help. If you have any suggestions it would be much apreciated
Thanks.
Thanks.
Run a check on the stator then..
