heel gram
modsrx
canada,qc
how mutch 1 gram add in eatch heel of heel clicker will effect the midrange
yeah i try to see if i can do something about those ............. clicker lolll...i'm sure i will finish to add some a little in middle hole
well i try things eatch time i go out for ride ... the sled pull hard till i hit 75-80 mph than the rpm always drop to 8200-8300.. i take off some weight on tip but didnt have a chance to go for a ride but i know i will overrave from a dead start till midrange now thats why i ask about heel ...or if its doesnt work ill put some in middle
ill let u know how it works sunday night :-)) i remove almost 1 gram tip so ill add 2 gramm heel to switch from 3 to 5 gram
modsrx said:
i'm sure he don't cause i think he did stuff with mr viper :-)))
i started stuff with the mister, but!! there is allways better.
well its gonna be hard cause i dont know where are those gramm in the weight and hp will effect too.. but i'm sure its gonna be close to 50-40 :-)) i see your video on you tube and your sled seem real fast i hope ill be able to make my srx pull like yours
i have allways had better luck using steeper helix,s with hc,s then what you guys use. I run a steeper helix in my nytro with hc,s & it works well.
big t, u know this allready, but a four stroke will allways eat more helix.
i used steeper helix,s in my srx,s buds viper, 700 mm all my 2 smokes. we use the white hc primary spring in the 4 strokes. using the red primary in the 2 strokes overcomes a lot of the primary weight/helix diff.
well i got a steeper helix here and ill let u know turk if i can find something good for my top end rpm problem... i hate that rpm drop at top end grrrrrrrrrrrrrrrrrr will see tomorow if my problem is better :-)))...
