fine tuning the /h/cs
SRXGTO67
NW IL.
Stock 98 srx 700 about 600 miles on a fresh rebuild Just installed 144 studs up the middle of a new compo 1" track. Need to fine tune the Heel Clicker 40-10by kit. I set it up per h/c instructions Red spring , 4.3 shoulder 3.3 ctr 3.3 tip w/ stock 47 helix, GREAT trail set up!! I would like to regain the top speed & rpms I lost wot @ 7900-8000. Removed the clutch & starting test #2 to regain top speed..
4.3 shoulder, 0 ctr, 6.3 tip, per h/c & TY clutch gurus move the ctr weight to the tip. Next (Helix) per h/c instructions & TY clutch gurus 50/40 ish ? issue i have is the diffrence in vendors micro-belmont, advant-edge, dalton ect. & differance in helix angles? & which to use & best for my application ? Any help from other ty members w/this set up or recommendation are apreciated. :o| Thanks
I LOVE MICRO - BELMONT HELIX,s !! 50-40 @ 2-6 WRAP MIGHT BE THE TICKET. IF RPM IS STILL LOW, BACK -OFF TIP WEIGHT. 98 SRX LIKE 8350. 3:16 (yammie tony)
YAMMIEGOD 3:16, Thanks for your reply, I will look for a Micro-Belmont 50/40 or a 48/40 Advant-Edge read some good things about them also ?
Any TY members have these & want to sell let me know Used or New , I tried both web sites no good ? are they not aval. to the public?
Thanks Tony (srxgto67)
TONY, I LEARNED WITH HEEL CLICKERS YOU HAVE TO FIELD TEST THEM. BUT THERE VERY EASY TO TUNE. AND ITS ACUTALLY FUN. WHEN YOU DIAL THEM IN, YOU WILL FLY. 3:16 (yammie tony)
