Limiter straps scraping suspension
A~T
Nova Scotia, Canada
Has any one had problems with the limiter staps being scuffed by the rear shock brackets. I'm thinking it happens when bottoming but i'm not sure.
Any body have any suggestions.
I have the same problem on mine, a 97 SX 700 equipped with long travel Öhlins at all four corners and Bender pipes. So far have destroyed 2 limiter straps at the left side (the straps are updated to longer Sxr type). I cant find any sharp corners or burrs on the W-arm and the only thing I can think of is the rear shock front mounting brackets coming into contact when the suspension is bottoming out.
