Stock suspension measurements needed
deepnsteep
Gillette, Wy
Anyone have the mount location dimensions for 2000+ geometry on the mountain proaction skids?? I would really appreciate the distance from the axle center to the front mount, the axle center to the rear shock front mount hole(s), and from the axle center to the scissor upper mount.
I have a MM with a Vanamburg tunnel and Northern Lites skid (2000 geometry). Sled came with adjustable transfer rods. I took them out and put limiter straps on. It doesn't transfer like my old MM at all. I can only get ski lift for a short distance. In the garage, I can't get the rear scissor bolts to go back very far......however I can see where the bolt has hit the rails. What is the clearance between the lower scissor arm and the rail? If I grind down the bolt head and nut, it would work, but there wouldn't be much left. I have my front limiters about half way, the TRA in the softest position, and I still need to figure out the shocks. They are some kind of aftermarket with titanium springs.
Thanks!
deep
