rx1jim
Does anyone have any tricks or magic cleaners to remove the exhaust residue from the right side plastic belly pan?  The pan right in the vicinty of the exhaust pipe is really coated.  This residue is easily removed from painted surfaces with wax.  I changed the right side belly pan at 6000 miles, looks like I have to do it again.  Yes, I'm nuts.  Any mark  or imperfection on the sled drives me crazy.
paint the panels with Krylon Plastic Paints.Did it on my SXR panels,works great.
Find your self a GOOD cleaner like simple green(full strength),or any type of degreaser/cleaner and pour the elbow grease to it...
most of it should come off
I still haven't till this day found anything that will get that residue off..tried again tonight with no luck....degeaser,goof off,simple green,vinager,brake cleaner..nothing cuts thru it...
"Spray Nine" is the strongest and most effective cleaner I have found for grease ect. Available at C-Tire here in Canada.
Bob
			Bob
A couple of bucks
Naptha or if ya really want it off....MEK. I wouldn't let the MEK sit for long at all as it will soften..........pretty much anything except metal.
			snoprokidf6
purple power
			Straight up 87 octane, works like a champ.
			Has anybody tried the Westley's Bleche White tire cleaner?  I wonder if that would work.  I think it has bleach in it.  I know it cleans a lot of other things very well.
