1977 srx clutch setup
edgeracer1
WEST CHAZY NY
Just wondering what a good setup would be for 660 ice drags. I am running a comet 102 any help would be appreciated.
YOU WILL NEED TO TEST BUT HERE IS BASELINE COMET SPRING # 208228A (yellow/green) CAN FINE TUNE WITH A SHIM OR TWO FOR ENGAGEMENT. WEIGHTS WILL NEED NOTCH BUT N-1 (209642A ) WORKED GREAT ALSO P-1 (209782A) BUT THESE NEED WEIGHT ADDED TO THEM. RUN 18-35 GEARING AND START OUT WITH SECONDARY SET IN STOCK LOCATION WITH THE 77 '' YELLOW '' SPRING. !! 3:16 (yammie tony)
ME BAD STICK WITH STOCK '' YELLOW '' SPRING. NOW I BELEIVE I MIGHT HAVE SOME OPTIONAL SECONDARY SPRINGS FOR THAT SECONDARY. THERE WAS A SILVER UPDATED ONE BUT THAT REALLY RAISED RPM BECAUSE I THINK IT SPECS TO A 440 EXCITER. LET ME KNOW HERE AND WHERE THE HECK IS WEST CHAZY NY. 3:16 (yammie tony)
YAMMIEGOD3:16 west chazy is about 2hrs north of Albany and as far as those spring go i have the update silver and a white. Also would you know where i could get a rubber track for this not a huge fan of the cleated. Thankyou
