TY2185
I know the electrical needs to be updated. Anyone do this upgrade or point me in the direction to someone that has?
You will need quite a bit of stuff, beside the pod. CDI, Stator, harness and so on...might be better off finding a totaled SX-R 01, the ignition on the duel headlight model fires the engine defferent then the older style too...
98srx6
Sounds like alot of work and money.....I think i would just choose to live with the poor lighting of the older pro-action sleds.
its not worth it for the cost, what I would do is get a xenon boosted 100/55 headlight and replace the tail light with a led bulb and your light will not dim with the brake and will have the best light possible in the old proaction single chasis.
TY2185
MrSled said:its not worth it for the cost, what I would do is get a xenon boosted 100/55 headlight and replace the tail light with a led bulb and your light will not dim with the brake and will have the best light possible in the old proaction single chasis.
Thanks for the reply. I knew about the Xenon and the LED tail.
I was hoping someone came up with somthing else since the last time I researched this. Thanks again MrSled
BETHEVIPER
Life Member
another option to power that bigger bulb is to have your stator rewound. dirt bikes have it done alot. check out a dirt bike mag and there will be like a dozen people doing it. i got a quote when i was going to do my srx, 125$, i sent him(stator king)a picture of the stator and a spec sheet on its output from the manual. he said he could increase the output atleast 20% maybe more. most stators are under wound.
another option is some guys are using some sort of boosted florecent or some dam thing. do a search in here and on yamahainfo.com also
98srx6
go to www.dirtrider.net to find out about people rewinding their stators on dirtbikes, as BETHEVIPER previously told you about.
Coldplay97
Life Member
TY2185, i went the way of silverstars and the led taillight, advanced auto or pepboys the light is the h4 std for a motorcycle 65w for $25 and $6 for the led...works great, good luck CP
Does anyone know what kind of led for a 2001 sx600r? Thanx Pete
Bulb is a 1157
Thanx mr sled. Sorrry I should have asked before but how many?
the rear bulb is single on a SX/vmax
jwiedmayer
I tried the HID it worked great but it only had low beams. They do make HID bulbs now that have high and low beams but they are pricy. You also have to run a battery and I never really got the charging system figured out. So I gave up and went back to the xeon bulb.
actionjack
What about adding a small HID light on either side of the headlight, ala the Redline Revolt lights or other small PIAA lights?
