Skidoo Sc3 Skid Dimensions
maxwell
Victoria, MN
Skidoo Sc10-3 Skid Dimensions, anyone have them?
I am in search of the dimensions for placing a sc10-3 skid in my srx.
Anyone have them?
A few people did them, I did a viper with drop brackets which won't help you, but becareful on year of the SC10III, the early years the front was bolted into the shaft like most others, later years had a tab welded on and used a bushing/bolt/nut to secure the front shaft, make sure which you have before proceeding.
Get them off dootalk for the correct geometry (axle to front, axle to rear, front to rear). This is an important triangle to keep especially with a SC10-3.
Then get input from the TY guys here that have tested actual installs to place this triangle relative to the tunnel and your front setup. The SRX really needs the front raised to make this work well.
