98 SRX 700 (Turk and others)
WedigSRX
Oconomowoc,WI
Got close to 10,000 miles on the SRX.
I will be putting new rings in this summer and possibly pistons if needed. Do you have any recommendations while I have it down ?
Like adding a extra base gasket to bring the port timing up to the newer models.
Check powervalves. if you add extra base gaskets make sure you cut the head the same amount plus 10k to make up for the lost compression.
