JENSEN
Hey boys, im going to convert 3 srx's to 144 this summer and was looking for some pointers. I think we're going to use the kit from Mountain Performance with the 17 degree approach angle, anti ratchet drivers, and not sure exactly wich track to go with. Now we will be trail riding these 40-50 % of the time but mostly back country riding. One of our machines is 136" with a 1.5 inch staggered paddle, but is completely useless in the deep stuff. I was thinking of going 2 inch. Now i realize we haveto use a 8 tooth driverswith a 2 inch, but how much gear do you think we will have to go down? Anyinfo on your set ups, tracks, gearing and clutching would be appreciated. Thanks
Mike
Mike
wmcquay
I have a mountain srx 2 inch paddles 8 tooth drivers under heavy load deep snow it ratchets and the track is very tight. When going down trail have to use scatchers to cool slides.I would go 8 tooth anti ratchet drivers all open window track fully clipped
wmcquay
also gear reduction is done with the smaller 8 tooth drivers
JENSEN
Yeah , I was going to go with some anti ratchet drivers because i allready have some problems with ratcheting. thanks for the info!!
151Viper
I would recommend finding used skids out of actual mtn sleds becasue they will work alot better for you in deep snow conditions. I also am not a fan of rail extensions. IMO
JENSEN
The rail extentions don't amuse me either, but it might keep the cost down a little. My rear suspenson has been long travelled allready. Are they really not that great in the deep stuff? if so, what's the major difference? why don't they work as well?
Mike
Mike
ViperXC
The approach angle at the front of the track makes a difference.
JENSEN
That's what i keep hearing, we will be doing that mod for sure! Now im looking for 3 144 inch 2 inch staggerd paddle tracks, new or used. what do you guy suggest? What kinda coin are we talking for a decent new one 5-7 hundo?
JENSEN
cacsrx1
Best thing to do is NOT use a proaction skid. Look around on ebay or snowest for a used Cat skid. WAY lighter, better ride, better aproach angle, cheaper and stronger than extensions.
ViperXC
3 whole different skids and swap out might get spendy IMO. Maybe you could get the MPI extension kits with the relocation template. This will reduce your approach angle and save some money compared to buying cat skids. Also, You will still have your shortie suspension that will work well on the trails since you will be riding 50 on/50 off trail. Like you mentioned, new tracks x 3 won't be cheap to start with on your project. For new tracks, I would check out Tracks USA and CBPerformance. Otherwise, just watch ebay, TY classifieds, or classifieds on other forum sites for used tracks.
cacsrx1
Take off Cat skid $300
Hartman tunnel extension and hose covers $240
Whal Bros 8T drivers $150
Take off Camo Challanger 2x151 $300
*sold* junk No Action 121 and track - $300
______
$690.00
I replaced all the jackshaft/driveshaft bearings also. IMO this route was way better that useing anybodys "kit".
______
$690.00
regert
cacsrx1 said:Take off Cat skid $300
______
$690.00
You have a pic of your sled or suspention set up?
JENSEN
^^^^what he said^^^^
cacsrx1
I sure do....(I will try to get some up tonight) buy the whole sled...lol...CPR 780 bigbore HP mid 160's, 151, Ohlins, Vforce 2, 4 window Digitron, new cdi-stator-bar warmers, 2 inch riser w/reinforced steering collum, SLP PowderPros, variflow, cold air kit, choice of 3 different cans. Just a few things off the top of my head. Pull the rope and go, for sale cheap.
Mysledblows
I set my srx with a 144x2. I used rail extensions the first time. It worked well, but I have now set it up with a 136 Polaris x-10 converted to a coil over. So far so good.
You can find good used tracks for $250 - $300 all the time if your patient. Other than the cost of the suspension I don't have more than $400 into my set up and then I sold the 121 skid with the extensions and made back a little better than half that. I could have done better, but I sold everything to my brother-in-law so I tried to treat him right. I've got one pic of it in the sled garage if you can find me in there.
cacsrx1
151 srxcacsrx1 said:I sure do....(I will try to get some up tonight) buy the whole sled...lol...CPR 780 bigbore HP mid 160's, 151, Ohlins, Vforce 2, 4 window Digitron, new cdi-stator-bar warmers, 2 inch riser w/reinforced steering collum, SLP PowderPros, variflow, cold air kit, choice of 3 different cans. Just a few things off the top of my head. Pull the rope and go, for sale cheap.
regert
what suspension is that?
