would a mountain max 700 136 skid be a bolt-in on my srx? and could i use my 02 viper shocks in the mountain skid? i know i would need to extend the tunnel and maybe move the mounting brackets fot the rear arm of the skid but i think the front might all bolt up what do you guys think
Depending on the year of the skid the front will bolt right in or not. When they changed to the 141 track the arm and mount points changed. The center and rear are going to require new holes no matter which year it's out of as the extra length is in the middle of the rail.
my srx is a 01 and the skid is out of a 99 136 i think
The front's should be a direct bolt in then. The center and rear will require you to measure/find the mount points and then drill some holes.
