where i can find the formula to know the gear ratio vs mph top speed ?
NOW WHAT?????
<--only 110 mph!!!!
<--only 110 mph!!!!lollll hey let me know where i can find the formula blue ..........atleast i did 110 u did maybe 100 all the winterlollllllllllllllll ....still have alots of snow here lolll
Wrong mod. I hit 110 a few weeks back and that was using a bad clutch that the belt wasn't climbing up the primary all the way.I am sure now that I would be 115 or a little more now with things running smooth again.I put back felt marker marks on the sheaves and can tell belt wasn't climbing up and clamping down.The other clutch the marks were rubbed off near the top and belt was clamping good.Just didn't have a chance to do a mile or so run because of the conditions out here.
well i put some marker on my primary and i have 5/16 where the belt don't climb i guess it must be the overdrive section of the clutch ... maybe i'm wrong too
#1 ski vbmenu_register("postmenu_109187", true);
Senior Member
Stock
Member #: 3231 Location: Steinbach,Manitoba ... yeah it IS in Canada eh!
My Sled: 2003 Yamaha RX1ER
Gear and Speed Calculator
I made up a little excel sheet with a gear chart for 8 and 9 tooth drivers and a speed calculator.... It is in Microsoft Excel format so you need that program to use it. Let me know if it works ok and if I should make any changes to it. Thanks -Steve
Click here to try it
Senior Member
Stock
does't seem to work.sorry I tried
terret725
send me an email at terret725@yahoo.com i have an excell spred sheet i got off this site a wile back i can send u
