bulldiesel
Hello Guys,
Just picked up a used 01 SRX and forgot to ask the guy the octane he was running and was wondering what is used in the majority of cases.
Stock motor with some clutch work.
Thanks,
Thanks,
at least 92 UNLEADED!!!!
yup at least 92,, OR higher if you can,,,use BR9ECS(0.028-0.031) plugs also..
jmp2204
sez minimum 91 octane on my sled
yamaholic22
yup need a minimum of 91 octane. Just use premium wherever you fill up and you will be fine. Those things run like tops.
bulldiesel
Thanks Guys
Marker
91 minimum but too high octane makes it hard to start at times for some reason...
