changing srx shocks to viper shocks
jkenosh
kenosha
i bought a complete set of viper shocks to put on my srx, are the a bolt it deal or are there other mods i gotta make
for rear shocks
pretty much bolt in
but, you will need to extend the transfer rods about 10mm and install proper plastic bushings to get the correct gaps
and lenghten the limit straps
I had the best handling with the fra (front rear adjsutment) to the softest setting for the best cornering. but there is more setin, therefore prolly a little less travel . personal preference
point is. use the adjustability features and dial it in to your liking. you will be surprised how much you can affect the handling and ride
the fronts need different brackets ( can be bought from betheviper)
Ramb
