Rambunctious
I burned down a cylinder after 5900 flawless miles because a spark plug was loose and it leaned down
I am in the process of a full rebuild to do it right
concerning the head. there are alum specs from the detonation
how can you properly clean it up without scratching any coating ( if any)
is it ok after clean up, or is a new head required
do they have an annodize finish or anything?
thanks
Ramb
thanks
Ramb
blue missile
muriatic acid just be careful it will eat the aluminum including the aluminum you want to keep.
If you find yours is banged up too let me know as I have 2 I'd like to sell for the 00-02 engines.
chuck it up in a lathe and either use sand paper to smooth it out or do a light cut if need be, there is no coating on the head, just bare aluminum. Dont use muratic acid as it will eat the aluminum, thats what you use on the cylinder plating to remove the molten/smeared aluminum.
Rambunctious
thanks
is there value in my jug that has smeared
aluminum? if it can get cleaned up?
I already bought al ow mileage jug and matching piston.
but if someome can use my other jug that would be good to know
fourbarrel, what you asking for your head if I need it
Ramb
aluminum? if it can get cleaned up? I already bought al ow mileage jug and matching piston.
Ramb
Ramb[/QUOTE]
I'd sell the 2 I have to you for $90 shipped to your address.
Ramb[/QUOTE]
