yamalube
FirstGenCTD
WA
So where do you guys that run yamalube get it. Just from a dealer or do you order it online?
I still run the yamalube in my phazers, but have switched to Klotz in my doo and poo sleds.
Should I just run Klotz in the ol' phazers?
-matt
Should not be an issue to run to the Klotz; I have mixed several brands through my older sleds( started with YAmmie lube and then went to Amsoil-in a pinch-I had to throw some 'Cat lube in the sleds once too). They are all running fine today. I don't see an issue.
It's up to you weather or not you want to use it,yes you can without problems,i run Amsoil in my '94.
back in the day when i ran yamasludge i got it from my dealer,that was the
cheapest place believe it or not...
