Where can I find the online high altitude jetting specs
I have seen them online before, but I can't remember where. I would search and post on snowest.com. They use those charts a lot more than the majority of folks on here.
In the meantime I'll see if I can find them.
On the other hand, you can simply do the calculations yourself.
Clutching you are going to want the 8vo's or 82m90's for weights. Something in the area of the red/pink spring in the primary. Secondary I'd just leave alone for one trip. Or tighten the spring one or two steps if you feel like tearing it apart.
Jetting is going to be bigger pilots and smaller mains. Stock was what 143.8's? You'll probably want to be in the 130 area for mains. It's been a long time since I've ran a phazer and even longer since a basically stock one.
CdnSxR6 said:
RevBaron,
check the link in the tech pages. There's one for phazer with some jetting and high altitude setup.
misc. tech page
Wow I didn't realize that this was posted here, I need to review the Tech Section again to see what all has been added in the last year or 2.
