which mounts are the best for a 01 srx going to a 02 viper set of shocks?
you can just offset the brackets and machine a spacer to go in between to keep from crushing the bracket/shock bracket when you tighten down the bolt.
motodave289
I installed BETHEVIPER's brackets. They worked pretty good.
