battery recharge
superviper
New Haven, Ct.
My battery is new but went dead when i went up north -32 degrees. can i give it a quick boost with a set of jumper cables from my truck????
You can jump it to start the sled, but it would be too many amps to leave it charge the battery. Check the owners manual for the maximum charge rate.
The temperature should not have discharged the battery, unless you cranked it enough to kill it.
