A
AIRWOLF
Guest
WHAT WIRE'S DO YOU TAP INTO ON A VIPER TO HOOK UP A TETHER SWITCH
snowprophet1
If it is the same as an srx...open up your handlebar pad, and tap the 2 wires into the kill switch circuit. There are 3 wires coming from the kill switch/throttle over-ride junction. Tap into the black wire, and the black wire w/white stripe. Leave the third wire as is. I just looked at mine to make sure. Easy.
A
AIRWOLF
Guest
THANK YOU !!!
srxbully
is a srx a closed or open circuit?
srxbully
srxbully
opps
snowprophet1
Well, I don't have my motor in the sled right now to check, but I believe if you have the sled running and pull the kill switch plug, I believe it still runs. The tether and kill switch would be completing a curcuit to kill the motor, so I think that means it is a normally open curcuit. I just drank 1/2 a beer, so if someone else has a better answer, maybe listen to them. (hicuppp!!!)
