Aftermarket Skis For sxr 700
pbspecial
Does anyone have experience with a good aftermarket ski setup for a 2001 sxr 700? I have looked at the SLP SLT as well as a Simmons Flexi ski, just not sure if these are godd and worth the almost $400? I'd like to reduce darting over the stock setup. I ride in Michigan on trails and ditches. Any help would be great.
Thanks![/b]
I second the C&A's, but darting can't be solved by different ski designs and materials.
Darting happens when you've got too much pressure at the front of the ski, and too little at the rear. Maybe you've noticed that your wearbars have worn heavily in front...?
Tech page has an article on darting, check it out, it's helped quite a few folks get their sleds to behave. And on the cheap!
Check it out.
