Apex Attak Rear Heat Exchangers
Iceman57
Royal Oak, MI
I talked to Kevin today and got the new pricing for the Rear Heat Exchangers for the Apex and Attak. Because the pricing has gone up substantially I was told that some are using the Apex cooler on the Attak. If you do use the Attak exchanger you can also purchase a factory heat exchanger protector that Yamaha now offers. If you do use the new protector you will have to drill out the rivets and remove the old protector and remove it and install the new longer protector which extends from over the rear heat exchanger all the way down the tunnel to the front where the stock protector ended.
Apex Exchanger
8ET-124A0-00-00 Retail $166.08 Your cost $124.99
Attak Exchanger
8FT-124A0-00-00 Retail $325.00 Your cost $229.95
Attak Tunnel Protector
8FT-21980-00-00 Retail $178.00 If you purchase these with the Attak heat exchanger you will get them at $129.00
Part Number
The most recent part for the 2008 Yamaha Apex LTX rear heat exchanger is: 8FT-1241A-00-00
Retail is $440.91
This information is from Hacker's Yamaha, Houghton Lake, MI.
A330Flyer - that part number (8FT-1241A-00-00) is just for the cooler - not the kit that Yamaha offers that comes with the cooler and the rivets to install it. The part numbers for the kits and current pricing is below. Give us a call if you need one.
121" Heat Exchanger Kit (Apex/Vector/RX-1)
8ET-124A0-00-00 Retail $207.28 Our Price $149.95
136" Heat Exchanger Kit (Attak/Apex LTX/RX-Warrior)
8FT-124A0-00-00 Retail $406.28 Our Price $299.95
