wkeggenhoff
Does anyone make triple pipes for the viper that will fit with reverse installed ? Thanks
NO, not officially but SLPs will fit with reverse. I can't find the picture I had but you need to shorten one of the battery support tabs and one of the battery support mounts (yes even if you don't have electric start).
Pic below isn't the one I was looking for but shows what needs to be done.
mopar1rules
i think the aaens work too.
CPR's
I'm pretty sure the CPR's will work with reverse too.
Madmatt
Madmatt
I have had SLP w/ reverse & electric start. It is a little touchy to do, but once done, works fine. I end up using a gell battery & had to use a MPI parking break. The brake linkage is the biggest problem. I was told the SLP are the quietest ones & have the most low end torque & CPR are a little faster, but louder.
Good luck with project
taped throttle
you will also need to relocate a bracket on the can.
i have a set of ceramic coated slp if your interested.
wkeggenhoff
What would you be looking for those ?
How much clutching and jetting are required ? Are the reliable power, not wanting to change jetting evertime the temp drops 10 degrees
