MSRXRider
I have some RUSH light weight trailing arms on my 98 SRX 700. So I was wondering if someone can tell me the length of a stock trailing arms. From the center of the spindle and the center of the mounting bolt by the foot well.
gild
T Arm
There is only a 2 Degree difference in caster angle between yours and all excluding the newer 8DM Ski with low profile ski saddle ( Viper Style ) That is lengthwise only.
MSRXRider
My trailing arms are adjustable. You can make them longer or shorter. I just dont know if the adjusted right,because they came on the sled when I bought it. I think they are set to short,because only the front of the carbides have wear.
gild
Trailing Arm
Its not the rubber cushion under the spindle on wrong? I'll measure my buds 98 MSRX and get back tomorrow
MSRXRider
they looked like they were on the right way. The big S for simmons was facing forward.
the lenghth, center to center, if you measure across the top with arm in running position is about 37 1/4 ". ive heard a lot of negative about the rush arms in the past. cant recall if it was product or business, but back then he was had the makings of good looking arm. i almost bought a set! also, as gild mentioned, check the ski rubbers. the simmons yamaha mounts came with a piece of white uhmw that also would gouge out, i used to just turn them over to the good flat side. good luck.
